Hi!
If you look the attached file… I have a fluid surface which is surrounded by a static object - acting as a tank, and a sphere that is falling into fluid.
The problem is that the fluid surface starts moving before the sphere hits it.
What is the “correct” way to stop this happening?
FLIP fluid without initial movement
7190 10 2- KiLa
- 109 posts
- Skybar
- 166 posts
What is happening is that the particles is reacting to the gravity. That in itself isn't a problem, but the collision volume for your tank isn't a tight fit - so naturally the water will fill out the empty space. You'd have to increase the resolution on your collision volume, or turn off “Use Volume Based Collision Detection” which nets you very accurate collisions quickly. I've been having some problems with that lately though, whenever I turn it off it literally rains particles out of nowhere - so I wasn't going to recommend it at first, but incase it works properly for you, it is probably what you want to do.
- KiLa
- 109 posts
- PradeepBarua
- 443 posts
- KiLa
- 109 posts
- hanton
- 36 posts
- johner
- 815 posts
Hanton's suggestion is a good one. Also you'll see more accurate sims with less erroneous movement at higher resolutions.
Finally, we recently discovered a bug in the way the FLIP solver does velocity extrapolation around collisions, which is what's causing those small “ghost” velocities around the bottom of the container. We're currently testing a fix in the development build, but are planning on backporting to 12.5 in the near future.
- KiLa
- 109 posts
- Skybar
- 166 posts
johnerOh that explains it, I could not wrap my head around why it was doing that. Please keep us posted!
Also, is this bug related to the strange things that happens when you turn off “Use Volume Based Collision Detection”? It has worked fine before, but now when I use it flip particles spawn out of thin air and rains down. I thought it was something else causing it before, but now I'm not so sure. You can see an example of this towards the end of this video: https://vimeo.com/70735913 [vimeo.com]
- johner
- 815 posts
SkybarjohnerOh that explains it, I could not wrap my head around why it was doing that. Please keep us posted!
This fix has finally been backported to 12.5 and should be available in tomorrow's build:
Journal entry
Fixed a long standing bug in the FLIP Solver that caused phantom velocities
along the bottom of curved collision containers such as bowls or cups.
There is a new parameter on the Solver tab to control the velocity
Extrapolation Mode, with a default of Normal that selects the new, more
accurate extrapolation method.
This change affects velocity extrapolation around collisions and at
the liquid surface, and should provide improved, but likely different
simulation behavior. Therefore the other option for Extrapolation Mode is
Compatibility, which retains the previous extrapolation behavior for
backwards compatability.
Hmm, I think you've always needed “Use Volume Based Collision Detection” enabled. FLIP needs to see collisions as SDF's to do a proper pressure solve.
- Skybar
- 166 posts
johnerGreat! Thanks!
Hmm, I think you've always needed “Use Volume Based Collision Detection” enabled. FLIP needs to see collisions as SDF's to do a proper pressure solve.Hmm yeah that could be it actually. I've been using it before with FLIP mainly because it gets you very accurate collisions very quick, but I guess it was the first time I used it while working with viscous FLIP without thinking about it. I've started calculating my collision volumes with VDB now though, which is quite fast as well and I like it. But this is good to know, thanks!
