There is FCurve node in ICE that like ramp node in vop. But I find Ramp node have only linear and ease-in-out curve mode. I want make a fast-in slow-out curve in VOP Net. How could I do?
FCurve node In ICE
7756 9 1-
- jerry7
- 681 posts
- anon_user_37409885
- 4189 posts
- pbowmar
- 7046 posts
You can still old-school it by using an animation channel, keyframes at 1 and 100 (and any inbetween) then use the ‘chf()’ function to look up into that curve. That's what all use grey-hairs used to use and still do when the Ramp parm lacks the interpolations you want.
Peter Bowmar
____________
Peter Bowmar
____________
- goldleaf
- 4292 posts
- オンライン
pbowmar
Wow, awesome tip!
I'm o.d.d.
- jason_iversen
- 13062 posts
Or use a Ramp spare parameter and chramp(), of course!
- pbowmar
- 7046 posts
- jason_iversen
- 13062 posts
Helps if I read the question, doesn't it?
ops:
ops:
- pbowmar
- 7046 posts
- jerry7
- 681 posts
pbowmar
hi pbowmar ,
chf() may not be driven by different point attribute in Vop network. but ramp can do it.
In SI, FCurve is very useful for tweak particle per-point attribute.
- pbowmar
- 7046 posts
Ah I see yes. In fact, you can use chf() with attributes, but in a clunky way: You make a local variable (which VOPs will create for you automatically in the Create Attribute VOP) then use that in the chf() function.
I agree that Ramp (particularly the Float Ramp) needs some love to get Beziers and other interpolations in there.
We use ramps extensively in Houdini too so I feel your pain.
Peter B
Peter B
Peter Bowmar
____________
Peter Bowmar
____________
