Windows 10 & RAM Consumption
7778 13 1- Luke Letellier
- 240 posts
- anon_user_37409885
- 4189 posts
A tack on question; has anyone tested jemalloc on Windows Houdini.
'Performance of tcmalloc/jemalloc over windows 7's system malloc'
http://stackoverflow.com/questions/23095862/performance-of-tcmalloc-jemalloc-over-windows-7s-system-malloc [stackoverflow.com]
- Luke Letellier
- 240 posts
- chrism
- 2494 posts
- Luke Letellier
- 240 posts
- tricecold
- 260 posts
chrism
Yes, I've been running the tech preview for months. Don't expect any significant performance improvements over win8.1 or win7.
so does that mean, we should expect some ?
Head of CG @ MPC
CG Supervisor/ Sr. FX TD /
www.timucinozger.com
- Anonymous
- 678 posts
- wharton
- 4 posts
I'm new and wanted to know if I can install Houdini in windows 10. Sorry, I don't create about my query.
seo agency Liverpool Street [seocompany24.co.uk]
- Grendizer
- 375 posts
Yes it runs on Win10.
However I have horrible lags while working. I'm not sure it comes from Win10. The problem is… In the system requirement [sidefx.com] it says I need 4Gb of RAM, but I'm learning Houdini on an old laptop which has only 3 Gb of RAM, is this the cause of the slow interaction?
What I find strange is that it's only slow in geometry level… In object level, the interaction is perfectly normal.
Houdini gamboler
- Anonymous
- 678 posts
- malexander
- 5161 posts
grendizer
What is the GPU in the system? Have you tried upgrading the driver for it lately?
- Grendizer
- 375 posts
Geforce 9600 MS with the latest Nvidia Win10 drivers.
I told you it's an old rig!!
Note : same thing happens with a new cube in a new scene. Only happens in component works. Sometimes the lag will just disappear , even in component mode, then reappear.
Softimage is not affected by this lag, and no I won't uninstall it!! 8)
Houdini gamboler
- malexander
- 5161 posts
My guess is that the geometry shader is causing a slowdown with the wire-over-shaded rendering when you're in SOPs. You can try switching the shading mode to “Smooth Shaded” instead of Smooth Wire Shaded". The 9600M GS only has 32 shader cores which is pretty meagre by today's standards and likely why it's lagging in that case.
- Grendizer
- 375 posts
