The new Poly Tools are great, but I find it hard to use them in sequence, because my selection means nothing going from a bevel to a PolyExtrude.
Steps to recreate.
1. Create a grid
2. Select some edge loops
3. Apply a PolyBevel and get the amount I want
4. With this selection still active choose PolyExtrude
5. Nothing…it tells me to make a selection again.
This is a workflow slowdown and should be active to use tools together.
Modeling tools drop selection.
6440 23 4- Werner Ziemerink
- 1265 posts
- anon_user_89151269
- 1755 posts
Yep, there's no selection after applying a bevel.
Weirdly enough, in the right lower corner, the info widget says ‘n primitives selected’ (even though we are in edge mode) and nothing happens when trying to apply an op.
In Softimage after you apply a bevel, the resulting edges are automatically selected which is useful sometimes, but personally not something I can't live without.
edit: reading up again your post it crossed my mind that you'd like to have those polygons (created inside the bevel) selected? I don't think it's good idea. Houdini does already enough auto-switching as it is. I wouldn't want another, in this case, Houdini to take me from edge mode to poly. After doing a bevel most of the time I remain in edge mode. Don't you?
- Werner Ziemerink
- 1265 posts
For hard surface modeling I think it is very necessary for PolyBevel(which does not work on polys) and PolyExtrude to maintain the selection and keep them active for the next operation.
The same goes when switching the operations. Allot of times I would like to make use of PolyExtrude and go straight in to PolyBevel to chamfer the extruded poly. Does not work either.
- 1755 posts
Werner Ziemerink
OK, please correct me if I've misunderstood you, but when you say “to maintain the selection” you mean: keeping the resulting edges selected after you bevel edges and keeping resulting polys selected after you extrude polys?
If that is the case, then I agree.
- Werner Ziemerink
- 1265 posts
- Werner Ziemerink
- 1265 posts
- 1755 posts
I know exactly what you mean (I know the gif is not for me), but one would need first to be able to apply a bevel to polys in H first in order to achieve that. Currently you can't - as soon as you press PolyBevel, H starts a pick session because is expecting an edge selection even though the bottom message prompts you to select points, edges or polys.
- SreckoM
- 379 posts
- 1755 posts
- SreckoM
- 379 posts
- Werner Ziemerink
- 1265 posts
- halfdan
- 599 posts
Werner ZiemerinkYeah, it's not switching to polygon selection, as it should (since polybevel can take points/edges/poly). It's defaulting to the edge selection, which is empty. If you switch to the poly selection, then you'll see it.
ID=71849
Time to smarten this thing up.
Halfdan Ingvarsson
Senior Developer
Side Effects Software Inc
Senior Developer
- Werner Ziemerink
- 1265 posts
- Anonymous
- 678 posts
halfdan
Is there a way to detect what selection mode is currently picked? In Hscript, Python and HDK? So we could switch tool mode? Any examples?
This would shorten the shortcuts list, since yo could have one shortcut for multiple modes and it would call proper tool for each mode. For example, pressing 'C' (Connect) while two polygons selected would call PolyBridgeSOP in polygon mode, AddSOP in point mode while two points selected and maybe SkinSOP in edge mode while two edges selected.
- halfdan
- 599 posts
mantragorahalfdan
In HDK, it's possible. You can call SOP_Node::nodeSelectionSet() on the display SOP, and on the GU_SelectionSet, call activeSelectionType().
Halfdan Ingvarsson
Senior Developer
Senior Developer
- 1755 posts
- cb
- 635 posts
McNistorhalfdan
Cool. Does this mean we're gonna soon have a new bevel or is this enlightenment going the current bevel tool?
The new bevel is almost imminent + anything that Halfdan will be improving on the selection side of things. We wanted the new PolyBevel to be ready for the H15 launch, but decided to play it safely and work on it some more.
Cristin
- 1755 posts
- Werner Ziemerink
- 1265 posts
- Anonymous
- 678 posts
cb
The new CookieSOP is almost imminent…
Cristin
Cool! Will you sneak it in in some daily build or will it debut in next H version?
halfdan
Bookmarked this to try. Thanks.
