Instant Meshes Bridge Sop
   71236   93   22
I haven't tried the latest branch yet, but mesh self-intersection can also happen in the standalone Instant Meshes application in some circumstances.
Disabling “pure quad mesh” (the quad dominant flag that Luiz mentions) fixes it, but at the expense of allowing N-gons.
# Build Instant Meshes Commandline
cmd = [instant_meshes]
cmd.append("-D")
cmd.append("-f")
cmd.append(numPolys)
cmd.append("-o")
cmd.append(out_path)
cmd.append(in_path)
lkruel
Hey guys,
Can someone send me one of those files that are erroring out? I haven't been able to reproduce it.
You can try hitting Clear Cache and seeing if the problem goes away. I'm wondering if that's an issue with loading the OBJs back in from IM or something that they're generating.
I've also pushed an update to the Development branch that adds the Quad Dominant option and control over the Crease Angle.
Hi!
I am attaching the bugged file. I have updated the tool to the latest one but it didn't help
Cheers!
Tomasz
InstantMesh_bug.hiplc (60.8 KB)
Hello! Big thanks for this tool
but I have an error
Has the overlap issue been fixed ? Instant Meshes is already part of Modo but I'd love to paint areas that I want to re-topologize manually as so those areas are deleted automatically for edge flow etc ?
【T】【C】【S】
I know you can paint a direction flow in the stand alone application.
Would it be possible to use Houdini attributes to act as those guides, so you can use the comb node for more control?
Octop
Unfortunately, this HDA is at the mercy of the commandline options exposed by the instant meshes tool. The curve/painting tools are all interactive parts of the GUI, so we can't currently add them in.
I'm o.d.d.
Christopher_R
Interesting. Do you have a reference (link) somewhere that they included/licensed InstantMeshes in Modo?
Doesn't seem to be listed in the credits, but references can be found elsewhere:
04 July 2017
Since version 10.2, Modo uses our Instant Meshes algorithm to implement its automatic retopology feature! The Foundry just released an interview with Wenzel Jakob [www.foundry.com] (PDF) about this technique and other recent projects in this area.
http://rgl.epfl.ch [rgl.epfl.ch]
lkruel
Hey everybody,
I put together a quick little SOP that lets you call instant meshes from inside Houdini.
For those that don't know, instant meshes is a really cool open source software that does a great job with quad remeshing.
https://github.com/wjakob/instant-meshes [github.com]
Looks great! Will definitely have a look at instant meshes
lkruel
Hey everybody,
Cool tool, I get an error, though, in Houdini 16.5.378 on Mac OS 10.13.3:
Instant Meshes location: $HOUDINI_USER_PREF_DIR/Instant Meshes.app/Contents/MacOS/Instant Meshes
Invalid source /obj/geo1/sop_instant_meshes1/python1
Error: Python error: Traceback (most recent call last):
File “”, line 41, in
File “/Applications/Houdini/Houdini16.5.378/Frameworks/Houdini.framework/Versions/16.5.378/Resources/houdini/python2.7libs/hou.py”, line 25010, in loadFromFile
return _hou.Geometry_loadFromFile(*args)
OperationFailed: The attempted operation failed.
Could not read from the specified file
Edited by Konstantin Magnus - 2018年3月12日 16:47:40
Konstantin Magnus
I'm getting an error too, except mine is a touch different (line 38 instead of 41 for me) Windows 10:
Error
Invalid source /obj/geo/sop_instant_meshes1/python1
File “”, line 38, in
File “C:\PROGRA~1\SIDEEF~1\HOUDIN~1.378\python27\lib\subprocess.py”, line 524, in call
return Popen(*popenargs, **kwargs).wait()
File “C:\PROGRA~1\SIDEEF~1\HOUDIN~1.378\python27\lib\subprocess.py”, line 711, in __init__
errread, errwrite)
File “C:\PROGRA~1\SIDEEF~1\HOUDIN~1.378\python27\lib\subprocess.py”, line 948, in _execute_child
startupinfo)
WindowsError: The system cannot find the file specified
Invalid source /obj/BP_rubblemaker/bricksmesh/sop_instant_meshes1/python1
errread, errwrite)
startupinfo)
tmishler
Konstantin Magnus
Error
errread, errwrite)
startupinfo)
errread, errwrite)
startupinfo)
No longer an issue for me.
tmishler
How did you solve it? And you are on Windows right?
Hello, has anybody ever experienced this issue of instameshes producing holes in the geometry?
Edited by Andr1 - 2018年4月18日 18:50:21
Yeah, it has a hard time with thin edges… You can try increasing your resolution, sometimes it helps
Luiz
Luiz Kruel
Senior Technical Artist
Konstantin Magnus
tmishler
i get the same python error always too. any update on that?
Same error like everyone else, any solution?
alperenozgur
Konstantin Magnus
tmishler
I have this issue as well.
It would be better to make Core-node instead bridge. I made it for Fabric Engine years earlier, it was easy https://vimeo.com/199342334 [vimeo.com]
