UV missing on alembic export
14109
7
2
ruudygh
2017年1月31日 5:37
I have a mesh with two UV sets, UV1 and UV2.
I export it as alembic, then import the same alembic back into houdini.
The imported alembic now have same UV on both UV sets, means both sets are UV1, and UV2 is missing…
Could anyone help? thanks.
UV_missing.hip (2.0 MB)
Enivob
2017年1月31日 8:38
Looks like a bug in Alembic. Just use .bgeo.sc file extension instead of .abc .
Using Houdini Indie 20.0 Windows 11 64GB Ryzen 16 core. nVidia 3050RTX 8BG RAM.
ruudygh
2017年1月31日 9:44
Enivob Looks like a bug in Alembic. Just use .bgeo.sc file extension instead of .abc .Thanks for the response. Now im gonna google on how to import .bgeo.sc into maya
AndyW
2017年1月31日 13:23
You might try exporting separate alembic files for each UV set, then consolidate them in Maya
2017年12月21日 19:22
Yes I'm having the same problem, using a new boolean sop and when I export alembic animation out of houdini into Maya theres some random uv's missing on frames of the animation, really crap. Anyone got any ideas?
2020年1月16日 13:57
Promote point attribute “uv” to vertex attribute. Just ran into this problem today. This fixed the export to alembic.
DGinz001
2022年6月23日 15:00
dennissedov Promote point attribute "uv" to vertex attribute. Just ran into this problem today. This fixed the export to alembic.that worked for me. Thanks!
2022年11月24日 6:40
I also encountered a similar problem.
In `rop_alembic -> Geometry -> Additional UV Attributes` add `uv*`.
This way all uv can be output to the abc file.
Edited by HenDaSheng - 2022年11月24日 06:40:40
