There was a kinda lengthy debate on FB on this topic, and I wanted to see if a SideFX employee could chime in…
As Users started to dive into the PackedPrim Instancing support added to Redshift, what the community discovered ( as stated by Tim ), was that for high Point counts ( >= 100k ), CopyToPoints was severely slower than the Instance OBJ node when performing the same tasks ( packing geo and then varying the geo that is instanced onto points )…..we even wrapped the CopyToPoints in a Compile Block and it was still much slower.
The performance gap we're discussing here is Cook time only.
Bonus Question: How do you use a SubNet with the Instance OBJ node (specifically, using a SubNet as the Instance Source via the Instance OBJ node parameter)? I couldnt even get that to work at all.
CopyToPoints vs Instance OBJ node with High Point counts
1852 5 2- TwinSnakes007
- 606 posts
- Andr
- 900 posts
- 7836 posts
The instance object doesn't have to cook anything, so of course it is faster by that metric. Copy to Points must create a prim for each copy, set a transform on the prim, and set a pointer back to the copy, as well as copy any template attributes that might be copied. The real question is, which is faster to render in Mantra? Instance points are probably still faster, but does the difference outweigh the convenience of copy to points?
- TwinSnakes007
- 606 posts
- mrCatfish
- 731 posts
Here is a great treatise on this topic: http://www.toadstorm.com/blog/?p=493 [www.toadstorm.com]
Sean Lewkiw
CG Supervisor
Machine FX - Cinesite MTL
CG Supervisor
- TwinSnakes007
- 606 posts
