I would like to render sequences and wedges with Arnold using PDG/TOP.
My current setup uses a ROP Fetch node that points to the out/arnold node. I plug-in the rest of my TOP network (wedges, …) as input to that ROP Fetch node.
This renders the correct sequence of images, although the shaders are missing (my geometry is all pink).
I am using Arnold's Standard Surface Shader in SHOP, which I assign to my geometry.
I read online that SHOP was deprecated but can't figure out how to define an Arnold shader without SHOP.
Any suggestions? Is there another way to render with Arnold using PDG than using a ROP Fetch node?
Batch renders with Arnold using PDG
6963 8 0- speierer
- kenxu
- 544 posts
- rafal
- 1449 posts
Houdini is backwards compatible and still supports SHOPs in older setups. So if you still have the Arnold's Standard Surface Shader SHOP, it should work fine.
Ultimately, it's up to the Arnold's ROP to interpret the shader networks (be it SHOPs or VOPs) and translate it to a format consumable by Arnold renderer. It may be worthwhile to ask on Arnold's forum about it.
- alexkohout
It looks like i ran in the very same issue. Is this actually an issue? I made a simple testscene with a wedge, a ropgeometry and a ropfetch. The material is set by a material node right in the geo-node. THe shader lives in “shop/arnold_vopnet1” The arnold rop is rendering fine by itself but if the render is triggered by the ropfetch the shaders get lost. The wedge is working fine though. I don't seam to find an answer in the arnold forum either. Any direction towards a solution is very much appreciated.
THANKS!
THANKS!
- kenxu
- 544 posts
Could you kindly post something on the Arnold forum, in that case? We’ll raise this as well with them whenever we get to meet. If you could upload a reference file, we can potentially work with them to correct the issue. Note however this may take a while, as it requires coordination between our two companies.
Edited by kenxu - 2019年9月18日 17:53:46
- Ken Xu
- comanche
I have problems too triggering an Arnold ROP via the ROP Fetch inside the TOP Network.
Could you please have a look at the scene file “Arnold-PDG-Test-2.hiplc”?
Project file:
https://1drv.ms/u/s [1drv.ms]!Aisf-Kb35NH2qQGDiQUaXSz70ONA?e=UyLvr6
Any ideas what's going wrong here? Maybe it's just me and the ROP Fetch needs some additional parms?
Thanks in advance,
Andreas
Project file:
Thanks in advance,
Andreas
- jedmitchell
- 39 posts
Same problem happening here, just installed htoa and any scene with an arnold shader in it prevents PDG from launching instances. It's like hython doesn't see the arnold plugin or something. Is there a separate environment file for hython somewhere that needs to have the plugin path added to it?
Edit: I should add that this happens whether an arnold ROP is being called or not -- any kind of ropfetch or other TOP that spawns hython instances breaks with the errors below, if an arnold shader is present in the scene:
File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.563/houdini/python2.7libs\hou.py", line 48581, in load return _hou.hipFile_load(self, file_name, suppress_save_prompt, ignore_load_warnings) OperationFailed: The attempted operation failed. Error loading: C:/path/to/file/untitled.hip Warning: Bad node type found: arnold::standard_surface in /mat/arnold_materialbuilder1. Error: Unknown operator on load "standard_surface1.def". Unknown operator on load "standard_surface1.parm". Unknown operator on load "standard_surface1.userdata".
Edited by jedmitchell - 2021年5月25日 21:18:55
- jedmitchell
- 39 posts
Well, of course after 6 hours trying to diagnose this it only takes one new search to find an answer:
https://www.sidefx.com/forum/topic/77814/?page=1#post-340670 [www.sidefx.com]
Hopefully that makes it appear a little higher up in the search results for someone else.
- RobertHellersdorf
- 3 posts
