I don't have a middle mouse button and hoping to continue to use houdini without it. Wall I'm running into is MMB clicking on a node to see attributes and other details. Right now using the “Show Information” shows only a limited amount of information on the node:
How do I get it to show all the information below without MMB(This is after I've plugged in a mouse with a middle mouse button)
Middle Mouse Button In Houdini (Without Middle Mouse Button)
11170 8 1- HappehLemons
- 19 posts
- 7801 posts
That's the same amount of information in the same dialog. The first one just hasn't cooked yet, so there's nothing more to show. Neither screen shot shows the info pop-up from the middle mouse, which has no menu bar like that.
The middle mouse button is indispensable in Houdini, and is listed as a requirement https://www.sidefx.com/Support/system-requirements/ [www.sidefx.com]
- mestela
- 1743 posts
You can fake it by remapping a keyboard button, but thats only a stop-gap solution. To use houdini properly, get a 3 button mouse (or at the very least a mouse with a clickable scrollwheel, which is 99% of mice these days).
Keyboard remapping trick: http://www.tokeru.com/cgwiki/index.php?title=HoudiniUserInterfaceTips#Houdini_on_a_laptop.2C_middle_mouse_button [www.tokeru.com]
- Charles Kirk
- 37 posts
Houdini works fine without the MMB on MacOS, you need to add the following to the “houdini.env” configuration file in “~/Library/Preferences/Houdini/17.0/”:
# HOUDINI MIDDLE MOUSE PAN ENABLE/DISABLE
# Tuesday 13th November 2018
# Source: Houdini Forum Topic “Middle Mouse on Macbook” 14th Jun 2018
# https://www.sidefx.com/forum/topic/56426/?page=1#post-252948 [www.sidefx.com] (penultimate post)
# System Preferences > Trackpad > Point & Click > Secondary Click set to:
# Click in bottom left corner or Click in bottom right corner.
HOUDINI_MMB_PAN = 0
I have included my comments (the lines preceded by a #).
HOUDINI_MMB_PAN = 0
Edited by Charles Kirk - 2019年1月27日 08:41:44
- HappehLemons
- 19 posts
mestela
This is just what I needed! Thank you
penboack
HOUDINI_MMB_PAN = 0
Thanks! Very useful.
- Cyzor
- 181 posts
Other options to provide a MMB-equivalent include jitouch [www.jitouch.com] and BetterTouchTool [folivora.ai], which let you map a three-finger click, for example.
- ENERGY
- kumpa
- 44 posts
- carlfairweather
- 6 posts
kumpa
I noticed that MMB click on node output no longer summons op menu and it is thus no longer possible to branch off new node. Bug or feature ? Is there any way to bring it back ? It is double plus moderately annoying.
I'm missing this feature as well. I've found a workaround by dragging a line away from the output of the node you want to branch away from, then hit tab. Your new node will be dropped outside of the flow.
