Is there a way to pull out the render settings from the viewport, and either save them to a file, or just use them in the node graph?
Pull out the render settings from the viewport?
3023 4 3-
- goldleaf
- 4282 posts
- mtucker
- 4566 posts
- BabaJ
- 2173 posts
- malexander
- 5301 posts
The viewport render settings are either taken from the active Render Settings prim (Persp > Render Settings) or the options found in the Render tab of the display options, if no Render Settings prim is used. The display option's render settings are initialized to the defaults specified by the render delegate.
- goldleaf
- 4282 posts
mtucker
This might be possible in a “snapshot”-style system, where the render settings would be copied (via python script probably) from the viewport display options to a newly created render settings node… If that's what you're looking for, please submit an RFE. If not, please explain further
Yep, that's what I was looking for; logged RFE #102031.
I'm o.d.d.
