I have a scene with a reference LOP that references an alembic file. While the scene is opened, I cannot overwrite the alembic file, as expected. But even when I close that scene, the alembic file cannot be overwritten. It can only be overwritten once Houdini is closed.
I have tried the same with usdview, having a usd with a reference to an alembic. While the usd file is open I cannot overwrite the alembic, but once I change the usd file to a new one, I can overwrite the alembic file.
Is there any way to unlock the alembic file without closing Houdini?
Locked alembic in a reference LOP
2950 3 0-
- Leire Foguez
- 8173 posts
- オンライン
Leire Foguez
I don't know about referencing alembic, but I noticed when I reference USD the lock is removed when the referencing node is deleted. Maybe that will work for alembic as well? Loading alembic in sops usually requires closing Houdini to release the lock. Locking alembics when read in sops may be a windows-only thing.
- Leire Foguez
- mtucker
- 4557 posts
Using low level Sdf Layer muting seems to allow this to work fairly robustly:
n = hou.node("/stage/sublayer1") # Bypass the node loading the alembic and force it to recook n.bypass(True) n.stage() l = Sdf.Layer.FindOrOpen("/path/to/alembic.abc") # SetMuted seems to throw an exception, even though it appears to work properly... try: l.SetMuted(True) except: pass # Copy the new file over /path/to/alembic.abc using shutil or whatever... # Unmute the layer (now with new contents), and unbypass the node so it will # recook again next time it is asked for its stage. l.SetMuted(False) n.bypass(False)
