how to promote the selection by group in Digital Asset?
   2525   5   1
Hi there,
I'm working on digital asset and I want promote the selection operation from groups when I press the enter key.
I share the example files also (I did the example with a simple subnet I think should be work in the same way).
How can I do it?
Thanks for you help and have a great weekend
Matteo
promote selection_2.png (166.8 KB)
file
promote_selection_test.hiplc (140.7 KB)
your action button script needs 'grouptype' and 'ordered' parms to be promoted from group to your HDA since it is using them to know what type of selection you want
if however you just want unordered point group as your current group sop suggests just change the action button script to this and you dont have to promote those parms:
import soputils
kwargs['geometrytype'] = hou.geometryType.Points
kwargs['inputindex'] = 0
soputils.selectGroupParm(kwargs)
promote_selection_test_fix.hiplc (153.3 KB)
tamte
import soputils
thank you now I try to apply to another complex hda.
Matteo
mh... i try to applied the same scripts to the group, but moved to OBJ level, I should change the soputils to another contex?
button obj.png (81.8 KB)
I did a variable for path and works
Thanks Tomas for your help
import soputils
path = kwargs['node'].path()+'/goal'
kwargs['node'] = hou.node(path)
goal_path python.png (615.0 KB)
