Import multiple fbx files in a for loop
   5477   5   1
Currently I am bringing in multiple fbx files based on an input folder using 'Python' node. This setup is working as intended.
import os
import hou
objects_path = hou.node(".").parm("import").eval()
folder = os.listdir(objects_path)
merge = hou.node("../").createNode("merge")
file_input = hou.node("../FILE_INPUT")
## Create loop that goes over the files in the folder
i = 0
for file in folder:
    if file.endswith(".fbx"):
        path = objects_path + file
        file_node = hou.node("../").createNode("file")
        file_node.parm("file").set(path)
        ## Connect files to Merge node
        merge.setInput(i, file_node)
        i += 1
file_input.setInput(0, merge)
Is it possible to create the same workflow using a 'file' node inside a for loop?
Edited by GlenD - 2023年3月31日 09:07:40
Have you tried the PDG/Top Network using the File Pattern node?
bentraje
Thanks, I will check it out.
Glen
I was able to look at the File Pattern node in the Top Network and it works as expected. The only issue is loading multiple files using an array. This video, 'Tech Talk | Process and Render Geometry and Textures with TOPS | Michael Buckley' goes over the process, just getting the array part to work is my current blocker. https://www.youtube.com/watch?v=L51DUKjrkIo [www.youtube.com]
Has anyone referenced an array in a file node using the File Pattern Top Network?
Edited by GlenD - 2023年4月11日 10:09:27
オンライン
use TOP Geometry SOP to load all your fbx files and pass through its output
https://www.sidefx.com/forum/topic/87322/#post-376990 [www.sidefx.com]
you can alternatively use File Merge SOP if the file names only differ with some number in name or alter it to fit your needs, but TOPs should allow you to do this out of the box
Edited by tamte - 2023年4月11日 12:19:54
CG Supervisor
Framestore, NY
tamte
Thanks! We ended up using the File Merge SOP, since we were having an issue of Unreal picking up the Files using TOP Geometry.
Glen
