Motion Blur Karma vs Mantra
1910 11 0- jerry7
- 631 posts
- Soothsayer
- 866 posts
- jerry7
- 631 posts
- jerry7
- 631 posts
- Soothsayer
- 866 posts
- jerry7
- 631 posts
- jerry7
- 631 posts
- 7863 posts
jerry7
It still has problems at specific parameters value.
Your camera shutter needs the same alignment as the samples. Without a camera primitive or karma render settings, it will use the default. By specifying time samples in a smaller window than the render, you're telling the object to be stationary for part of the shutter window.
Edited by jsmack - 2023年4月13日 01:12:16
- jerry7
- 631 posts
- Soothsayer
- 866 posts
- 7863 posts
jerry7jsmack
Your camera shutter needs the same alignment as the samples...
I added a camera, the problem still existed.
Cache LOP seems to be broken. If I set time samples on the node that creates them, it works fine.
Edit:
This is truly a bizarre issue. The usda files are nearly identical. The only difference is that the cache lop seems to write the time samples with full 64bit precision where as the time samples created on the transform appear to have been 32 bit at some point before recording at 64.
Cache:
0.85: ( (1, 0, 0, 0), (0, 1, 0, 0), (0, 0, 1, 0), (0, -1.15, 0, 1) ),
1: ( (1, 0, 0, 0), (0, 1, 0, 0), (0, 0, 1, 0), (0, -1, 0, 1) ),
1.15: ( (1, 0, 0, 0), (0, 1, 0, 0), (0, 0, 1, 0), (0, -0.8500000000000001, 0, 1) ),
No Cache:
0.8499999940395355: ( (1, 0, 0, 0), (0, 1, 0, 0), (0, 0, 1, 0), (0, -1.1500000059604645, 0, 1) ),
1.1500000059604645: ( (1, 0, 0, 0), (0, 1, 0, 0), (0, 0, 1, 0), (0, -0.8499999940395355, 0, 1) ),
Edited by jsmack - 2023年4月13日 15:54:58
- jerry7
- 631 posts
