Generating Points around a point
1235 10 0- Cola8
- 10 posts
- CYTE
- 679 posts
Hey Cola8,
I would suggest a bevel set to crease with two divisions. Unfortunately in my test, it yields an undesired result for a square curve. for poly, it works fine. maybe you could start with a poly do the bevel and then convert it to a curve. (you can use the LABs tool edge group to curve for that.)
Or if you need to use the curve, convert it to a poly with the fill node. After that use a blast and blast Primitive 0 (the curve). then do the bevel and convert it back to a curve with the LABS tool.
CYTE
CYTE
Edited by CYTE - 2023年4月17日 13:14:30
- Cola8
- 10 posts
- animatrix_
- 4515 posts
You can do this easily using a primitive wrangle:
float ndist = ch("distance"); int isclosed = primintrinsic ( 0, "closed", @primnum ); string polytype = isclosed ? "poly" : "polyline"; int primpts [ ] = primpoints ( 0, @primnum ); vector pos [ ] = { }; foreach ( int pt; primpts ) { vector p = point ( 0, "P", pt ); append ( pos, p ); } int count = len ( primpts ); int sharedpts = 0; if ( primpts [ 0 ] != primpts [ -1 ] ) { if ( isclosed ) { append ( primpts, primpts [ 0 ] ); append ( pos, pos [ 0 ] ); } } else { count -= 1; if ( !isclosed ) sharedpts = 1; } int newprimpts [ ] = { }; for ( int i = 0; i < count; ++i ) { vector p0 = pos [ i ]; vector p1 = pos [ i + 1 ]; vector pnew0 = lerp ( p0, p1, ndist ); vector pnew1 = lerp ( p0, p1, 1 - ndist ); int pt0 = addpoint ( 0, pnew0 ); int pt1 = addpoint ( 0, pnew1 ); append ( newprimpts, primpts [ i ] ); append ( newprimpts, pt0 ); append ( newprimpts, pt1 ); } if ( sharedpts ) append ( newprimpts, primpts [ 0 ] ); removeprim ( 0, @primnum, 0 ); addprim ( 0, polytype, newprimpts );
Edited by animatrix_ - 2023年4月17日 13:50:59
- CYTE
- 679 posts
- CYTE
- 679 posts
- Cola8
- 10 posts
Hey, I am not yet experienced with coding in Houdini @animatrix,
I've tried your code and all the extra points are stacked on each other.
@CYTE
I've tried a few solutions but all of them give me the same result where nothing changes.
Maybe it has something to do that the shape is linked with different attributes. I am practicing procedural modeling.
@CYTE
Edited by Cola8 - 2023年4月17日 13:36:04
- animatrix_
- 4515 posts
CYTE
@animatrix,
your solution produces a new point at zero for me? any way to prevent that?
CYTE
Yes I think your curve is unrolled with shared points so point 0 is used twice in the polyline. So to make it work as is, put an Ends SOP before the primitive wrangle, with Close U set to Close Straight and then another Ends SOP after the primitie wrangle with Close U set to Unroll with Shared Points.
- CYTE
- 679 posts
- Cola8
- 10 posts
- animatrix_
- 4515 posts
Cola8
It would help to see your geometry because there are a lot of nuanced differences between polygonal curves in Houdini.
