is there a way to hide menubar with python or hscript?
   3747   10   2
so I tired many ways...
but I can't find any solution for that...
for other panels or shelf I found:
hou.ui.paneTabs()
or
viewerstow -t stow -b stow
then I tried
hou.qt.MenuBar().close()
hou.qt.MenuBar().setvisible(False)
nothing works....
Hey JinChaoH,
I use this python snippet to toggle bars and stowbars:
b = hou.ui.hideAllMinimizedStowbars()
b = not b
for p in hou.ui.panes():
    p.setShowPaneTabs(not b)
for p in hou.ui.paneTabs():
    if p.type()!=hou.paneTabType.NetworkEditor:
        p.setShowNetworkControls(not b)
    if p.type()==hou.paneTabType.NetworkEditor:
        p.setPref('showmenu',['0','1'][not b])
    elif p.type()==hou.paneTabType.SceneViewer:
        p.showDisplayOptionsBar(not b)
        p.showOperationBar(not b)
        p.showSelectionBar(not b)
        if p.includeColorCorrectionBar():
            p.showColorCorrectionBar(not b)
        if p.includeMemoryBar():
            p.showMemoryBar(not b)
hou.ui.curDesktop().shelfDock().show(not b)
hou.setPreference('showmenu.val',['0','1'][not b])
hou.ui.setHideAllMinimizedStowbars(b)
Thanks, this works like charm
yeah I am not really sufficient with houdini document, the information is everywhere
anyway thanks again,
never able to think that setPreference can do the trick
CYTE
hou.setPreference('showmenu.val',)
sorry to bother you agian... well
just wondering where can I find the information about the values like 'showmenu.val'
in the document : https://www.sidefx.com/docs/houdini/hom/hou/setPreference.html
[www.sidefx.com]
there is no information about the "name"
Thanks again
Hey JIn_,
sry, I think this code is part of qlib and I have no clue how to put something like that together
CYTE
hey CYTE:
Thanks a lot
yeah I guess try to look into the qlib is one way.
the
hou.getPreferenceNames
can give some vague idea as well
calling deleteLater() on the toolbar object schedules it for deletion and completely removes it also from the view -> toolbars menu. Note that you won't be able to further use the toolbar after that, for example re-adding it with iface.addToolBar(toolbar) will not work.
toolbar = QToolBar('Test Toolbar')
# Add to main window & to 'View' menu
# Remove from main window & 'View' menu
toolbar.deleteLater()
On a related note, is there a way to hide the playbar via Python? It's not in the pane list and I can't see to find anything obvious in the API. thanks!
jbudsberg
Per SESI's comment this is not possible:
"I don't think we have any ability to hide the playbar at all, so there's nothing to add to HOM for this."
I filed an RFE for this #127072. So bump it up if you wanna see it in Houdini
thanks for the heads up! best I could find so far is this one:
hou.playbar.showRangeSlider(0)
Edited by jbudsberg - 2023年4月28日 17:50:49
Hello this is Gulshan Negi
Well, you can also try this code to the so.
from PyQt5.QtWidgets import QMainWindow
class MyMainWindow(QMainWindow):
def __init__(self):
super().__init__()
self.menuBar().setVisible(False)
