Hey folks! Thanks for the feedback regarding all of this. The system requirements page has been updated to reflect the updated driver requirement. Take care and have a happy holidays!
https://www.sidefx.com/Support/system-requirements/ [www.sidefx.com]
Karma sequence render issue, exit code -1073741819
7203 37 12- Tobias_SFX
- 6 posts
- in_am_i
- 9 posts
Hello.
I also stuck with the same error. I update Houdini to latest version Houdini FX Version 20.0.547. latest nvidia driver. problem with Karma both XPU and CPU, single frame rendering are fine, but when I try to render frame range, error appear after first frame stop render. I tried on scene with simple box in it, but render is the same. I don't have redshift, but I have instaled V-ray, that works fine. My workstation spec:
Operating System: Microsoft Windows 11 Pro x64
Number of Cores: 32
Physical Memory: 127.21 GB
Number of Screens: 1
Screen 0: 2560 x 1440 at 0,0
Work Area 0: 2560 x 1392 at 0,0
Screen 0 DPI: 108.9
Platform Build: windows-x86_64-cl19.35
Python Version: 3.10
Qt Version: 5.15.2
USD Version: 23.08
UI Scale: 1.000
OpenGL Vendor: NVIDIA Corporation
OpenGL Renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2
OpenGL Version: 4.6.0 NVIDIA 546.33
OpenGL Shading Language: 4.60 NVIDIA
Detected: NVidia Consumer
24564 MB
546.33.0.0
Number of Cores: 32
Screen 0 DPI: 108.9
Qt Version: 5.15.2
USD Version: 23.08
UI Scale: 1.000
24564 MB
546.33.0.0
- brians
- 477 posts
in_am_i
Are you getting the same exit code -1073741819?
If it's affecting KarmaCPU too, then it is not GPU driver related, and we'll probably need a repro scene+steps to debug further. Better to file that as a bug than on the forum.
- in_am_i
- 9 posts
briansThanks for the answer. I already disscused problem with support, and maybe problem was in V-ray, as I just installed Daily Build, without v-ray, and everyhing start working. BTW, all my drivers and updaets is up to datein_am_i
- micromammoth
- Qhuman
- 3 posts
- mohs3nn
tbattistettiI have this problem too, but unfortunately the problem persists even with the nvidia driver update (v551.23).brians
Hi guys
Its looking like this is an NVidia driver issue (windows only).
The good news is that it seems fixed in their very latest driver.
Could you please test with 546.33 (available in both studio and game-ready) and let us know if it fixes this crashing issue?
thanks very much!
Confirming, working as expected now!
Cheers!
But I should mention that there is no problem with CPU rendering
- S-kitagawa
- 39 posts
- brians
- 477 posts
- Qhuman
- 3 posts
- brians
- 477 posts
We've found the 550+ NVidia drivers have an issue.
To fix it you can set this environment variable
KARMA_XPU_OPTIX_ENABLE_OPTIXIR=1
but if you drop back to a 545 driver, then it needs to be set back to 0
Please let us know if that solves your issues with the 550+ drivers.
We're waiting on a response from NVidia to confirm the issue on their end, and any kind of estimate on when it might be fixed.
- sniegockiszymon
- 67 posts
briansI've 551.52 and with this enviro var set to 1 or 0 issue still occurs. (I dont have hairs in scene). With 546.33 and set to 0 seems to work fine, but other cuda errors (like bad memory adress?) often occurs
Edited by sniegockiszymon - 2024年2月19日 10:19:30
- brians
- 477 posts
sniegockiszymon
Ok, this sounds like another driver issue :/
Can you put together a repro scene (+ instructions) and submit as a bug?
thanks a lot
- SiRpRoHxO
- 95 posts
- brians
- 477 posts
SiRpRoHxO
Any news on this?
No, AFAIK the user never logged a bug.
SiRpRoHxO
With drivers below 546.33 i get the exit code -1073741819 when rendering sequences and with 546.33 and above i don't have gpu support. No matter what is set in the houdini.env
Im on latest daily build 20.0.649 and a rtx 3060
We don't get anything like this on our end.
Are you Windows or Linux?
Could you log a bug with a repro scene + specific repro steps? And we will investigate and report back.
thanks
Edited by brians - 2024年3月17日 20:27:27
- SiRpRoHxO
- 95 posts
- brians
- 477 posts
SiRpRoHxO
hmm strange, according to the nvidia control panel I'm on 546.33 and GPU isnt working... (Im on Windows)
If you confirm that 546.33 is working on your end, I need to investigate
Otherwise i try to create a repro scene
I've tried with 20.0.625 and 546.33, and Karma XPU is working fine for me.
And are you saying with a more modern driver you get no GPU support at all? What happens in the viewport? Is it just sequence rendering that is broken for you? Or is it XPU in general?
thanks
- SiRpRoHxO
- 95 posts
