Better visibility of selected nodes
788 10 2-
- toonafish
- 425 posts
Does anyone know if there's a way to adjust the way a selected node is visualized in Houdini, so its easier to spot whats currently selected ?
I checked the prefs, but nada.
The tiny yellow border is hardly visible on a 4K monitor, so it would be nice if it were somehow possible to adjust the color of the whole node or something like that.
Thanks.
Thanks.
- EZiniT
- 29 posts
If I understand you the blue display/render flag is active on for example a sphere node and you select/activate another node like for example a box node and want to change how this active node is viewed?
To do this press "d" in the viewport..."markers tab"
"set display options for" : current model geometry
Then change the drop down menu under "draw" to whatever you prefer.
- toonafish
- 425 posts
- EZiniT
- 29 posts
Ah gotcha...just briefly looked for a chance that the global UI scale or network view display options maybe had something but as you said seems like nada.
I have seen people do some pretty funky things in the network view with python, perhaps that's an option.....I would be interested if you find anything as I just picked up a new 4k monitor and had not even really noticed.....until NOW!
![](/static/djangobb_forum/img/smilies/big_smile.png)
- toonafish
- 425 posts
- AslakKS
- 171 posts
Here is how you could do it, copy these files from the houdini install directory to your user directory
Then open up the NodeGraphCommon.inc file in a text editor and change this value "GraphBorderWidth: 2" to something larger
You can then either restart houdini or refresh the color scheme:
![](/forum/attachment/59eff65678957d267897339cf090c292fa68567d/)
Proof that it works![](/static/djangobb_forum/img/smilies/smile.png)
NodeGraphCommon.inc NodeGraphDark.inc NodeGraphLight.inc NodeGraphPro.inc UIDark.hcs UILight.hcs basic_colors.inc
Windows:
Copy from:
C:/Program Files/SideFX Software/houdini20.0.*version*/houdini/config/
Copy to (create config directory if it does not exist):
*username*/Documents/houdini20.0/config/
Linux:
/opt/hfs20.0/houdini/config/
~/houdini20.0/config/
Proof that it works
- toonafish
- 425 posts
- EZiniT
- 29 posts
- AslakKS
- 171 posts
- animatrix_
- 4549 posts
I always wanted to add some overlays for the display, render, and output nodes on screen that has the same size on screen regardless of zoom levels and text, i.e. 1 for output:1 and a large hollow circle with distinct colors to immediately see the key nodes.
I have to investigate how to do this, not sure if the network editor supports this kind of decorators based on visible nodes or if it would require Qt tricks.
![](http://imgur.com/fY0VxdV.png)
- maitlandvt
- 12 posts
