Viewport preview inside Vellum Solver
   7430   21   2
Hello all,
This is a bit of a newbie question but I'm following some tutorials on Vellum and everyone seems to be able to preview their sims while inside a Vellum Solver. However, I can't seem to do this. When I press play the sim is just frozen on the current frame unless I go up to the top geo level.
I've tried turning various knobs in order to make it work but nothing seems to improve the situation. Can someone help as it would save me a whole bunch of button clicking?!
DT
meshmashuk
Hello all,
DT
I was about to report that as a bug. The issue isn't actually with the vellum solver. In houdini 20, if you create a subnet in a dopnet, the viewport won't update when inside the subnet. When you double click the vellum solver sop to go inside, it actually takes you inside a subnet in the dopnet, hence why it doesn't work. You can re-create the issue like this:
1. Create a sphere and select it
2. In the rigid body shelf on the right click RBD objects
3. Go inside the autodopnet
4. create a subnetwork
5. attach the subnetwork to the post solve of the rigidbodysolver node
6. go inside the subnet
you will notice the viewport will not update.
going to report this issue now.
update: known bug
Edited by evanrudefx - 2024年3月6日 16:07:27
Thanks,
Evan
Hey, is this fixed? Even now at 20.0.717 it's like this for me. It's extremely frustrating!
mike_keys
no, support told me it would not be fixed until next version. kinda insane that all houdini 20 will have this bug.
Thanks,
Evan
As a workaround you can pin the viewport when outside of the solver
CG Supervisor
Framestore, NY
Yes, you can! But you don't have any visual feedback on any of the pop nodes, gas nodes, etc!
this bug is extremely frustrating I can't believe they won't fix it, I feel it's a shame honestly however I found the only way to work and visualize pop forces is to build a dopnet with vellum solver and vellum object its so far the easiest way, pinning the viewport doesn't work you can't work with forces which makes vellum useless anyway
Screenshot 2024-05-30 234337.png (71.6 KB)
Maybe you can try this build
20.0.724
Fixed viewer update of a SOP Solver sim when inside the solver.
CG Supervisor
Framestore, NY
tamte
20.0.724
I've seen on the changelog clearly this update but still I'm having the same issue it's weird does it have anything to do that I install from launcher maybe?
insane bug
Daily Build: 20.0.758
- Fixed viewer update of DOP simulations when inside solvers.
Maybe this fix will finally do the trick.
alexwheezy
Hope that's it,
I'll give this build a try today this bug drove me insane on a project I was going back to 19.5 just to sim the vellum part and cache it and read it in my main project
I think we almost close to 20.5 thats what i was waiting for
Just saying: it's insane this bug slipped its way into not just one, but two production builds. The latest production build is still broken.
Edited by kodra - 2024年7月6日 19:04:00
This is seriously some weird bug after it was resolved in H20 build 20.0.762 it came back in H20.5.278 first production build of 20.5 and now we have to live with it again in 20.5 that's so frustrating
AAburady
Yea, this is very frustrating. I reported the bug to sidefx (again). I would just say to do the same thing. This bug is really bad. It basically makes all the sop versions of solvers useless because you cant go inside and have the viewport update. Pinning the viewport isn't much help either.
Edited by evanrudefx - 2024年7月10日 16:34:28
Thanks,
Evan
Don't panic, it looks fixed in one of the daily builds.
20.5.286 Fixed viewer update of DOP simulations when inside solvers.
Viewer is bugged again! (PANIK)
It's fixed in daily build. (KALM)
Daily build is not available! (PANIK)
please can anyone help? its still broken in version 20.5.318 for the pyro solver.
edit: I finally got it working after re-opening the project/resetting the viewport multiple times.
edit 2: It's still glitchy compared to 19.5 but at this point I give up as I have found workarounds.
Edited by evanrudefx - 2024年8月7日 18:25:40
viewport glitch.gif (1.3 MB)
Thanks,
Evan
It's still broken in 20.5.315...
wanglifu
Yea, its actually worse than before. Everytime I switch back to a dopnet I have to reset the viewport and disable/re-enable a node. Its so bad.
Thanks,
Evan
