More Adaptive Curve Resample?
   1772   6   1
Currently, if I resample a super high res curve, it spaces out each points by the exact same distance. Is there a way to have more points in complex areas? For example, if I resample a spiral curve, I end up with too many polygons on the outside and not enough points at the center.
In other words, is there an equivalent to Polyreduce but for curves?
-Olivier
Look for Ramer-Douglas-Peucker (RDP) algorithm. Fabian Hirschmann made a Python implementation [github.com], which is easily portable to an HDA. It's not too fast, but it works very well.
Edited by ajz3d - 2025年5月8日 14:20:41
Here's a short video that I rendered years ago, which demonstrates how the algorithm performs geometry-wise. The number in parenthesis is the current number of points in the curve.
Edited by ajz3d - 2025年5月8日 14:33:28
rdp.webm (115.4 KB)
Interesting method. I'll try it out. Thanks!
node = hou.pwd()
geo = node.geometry()
epsilon = 0.5
class Point:
    def __init__(self, index, pos):
        self.index = index
        self.pos = hou.Vector3(pos)
def douglas_peucker(points, epsilon):
    if len(points) < 3:
        return points
    start, end = points[0], points[-1]
    max_distance = 0.0
    index = 0
    for i in range(1, len(points) - 1):
        distance = point_line_distance(points[i], start, end)
        if distance > max_distance:
            max_distance = distance
            index = i
    if max_distance > epsilon:
        left = douglas_peucker(points[:index + 1], epsilon)
        right = douglas_peucker(points[index:], epsilon)
        return left[:-1] + right
    else:
        return [start, end]
def point_line_distance(point, start, end):
    if start.pos == end.pos:
        return (point.pos - start.pos).length()
    line_vec = (end.pos - start.pos).normalized()
    point_vec = point.pos - start.pos
    d = line_vec.dot(point_vec)
    projection = start.pos + line_vec * d
    dist = (point.pos - projection).length()
    return dist
points = []
index = 0
for pt in geo.points():
    points.append(Point(index, pt.position()))
    index += 1
simplified_points = douglas_peucker(points, epsilon)
result = []
for i in range(len(simplified_points)):
    result.append(simplified_points[i].index)
geo.addArrayAttrib(hou.attribType.Global, 'result', hou.attribData.Int, 1)
geo.setGlobalAttribValue('result', result)
int pts[] = detail(0, "result");
if(len(pts) > 0 && find(pts, @ptnum) < 0)
    removepoint(0, @ptnum);
Conservation of Momentum
The refine node reduces the number of points within a user-defined tolerance:
https://www.sidefx.com/docs/houdini/nodes/sop/refine.html [www.sidefx.com]
Labs offers resampling by density that can be set to curvature:
https://www.sidefx.com/docs/houdini/nodes/sop/labs--curve_resample_by_density-1.0.html [www.sidefx.com]
And for adaptive resampling I would accumulate the curvature along the curve and resample it.
Edited by Konstantin Magnus - 2025年5月10日 09:29:54
resample_adaptive.hip (202.6 KB)
Konstantin, that adaptive resample is really impressive. I just wish I was clever enough to really understand what you did there : )
