Well I think APEX Script is cool, but it doesn't seem to be easier to debug than manipulating a graph with Python...
How do you even print a debug message?
https://www.sidefx.com/docs/houdini/character/kinefx/apexscriptfunctions.html#specialfunctions [www.sidefx.com]
...is the only way creating a sticky note...?
APEX Script: how to debug?
4513 15 3-
- kodra
- 373 posts
- jonathangardner
- 47 posts
Hey Kodra,
In H20.5 there isn't a good way to print debug messages from an APEX graph (or from APEX Script) but we're aware of this gap and we're working on a
Once the design of it is finalized, we'll add printing support to APEX Script.
Logcallback for APEX that could be used to log messages, warnings, and errors as well as throw custom error messages to our nodes which invoke APEX graphs.Once the design of it is finalized, we'll add printing support to APEX Script.
- christopherk
- 73 posts
Hi there, yes we are unfortunately currently missing print and error callbacks in APEX. In the meantime, I find the best way to debug is to format debug log statements as strings using the string::Format callback and associated string formatting syntax in APEX Script, and then wire the debug strings to the output of the graph, or collect the list of all debug prints in a StringArray and wire that to the output of the graph. I also find the "Inspect Line" feature quite useful for finding where in a graph a particular line corresponds to, so that I can directly inspect the graph to find issues there.
- elovikov
- 154 posts
in the meantime this stupid trick can work:
I've attached the hip as well. the only thing is connect the output, even void one
not sure how log callback would be different, but this workflow is a bit painful
I personally think apex engine would benefit from any sort of conventional tagging, like if I'm tagging node (function, subnet, whatever) as traceable it just dump it's inputs and outputs. this alone actually would cover a lot of debugging
- cwrenniks
- 24 posts
- オンライン
- raincole
- 714 posts
- オンライン
cwrenniks
Is there a way to do something like this but get the debug information while in the animation state? I want to debug my rig graph values while animating my character.
The above RunVex trick should work in animation state as well.
But man it's such a hack and extremely painful to debug this way.
- cwrenniks
- 24 posts
- オンライン
I'm not seeing how to get the data in real time, while moving a rig. As an example, imagine outputing the translation vector while manipulating a joint. Is there a way I'm missing to do this? I'm starting to go down a path to figure out how to just log the information to a file, but that is also a pain.
- Fraenk
- 29 posts
- オンライン
- markwilly
- 4 posts
kodra
APEX Script: how to debug? 1225 7 2SUBSCRIBE REPLY
kodra
July 13, 2024 4:45 A.M.
To debug APEX Script, you can use the print() function to output messages in the Houdini console. For more advanced debugging, set breakpoints or use Houdini’s debugger. Sticky notes aren’t necessary for debugging.
- Fraenk
- 29 posts
- オンライン
- gpss
- 7 posts
elovikov
in the meantime this stupid trick can work:Image Not Found
I’m facing an issue with debugging in Apex Script when using the Apex Autorig Component. Here’s the scenario:
I’m using the Use Second Input option in the Apex Autorig Component and connecting an Apex Script to the second input.
However, this approach doesn’t seem to work properly, especially with functions inside the Apex Script.
Specifically, I’ve created a function that I plan to add to the network using addSubnet. The issues I’m encountering are:
The Log inside the function does not work.
I intended for the function to return debug_msg and set it as a detail attribute in base.skel. Unfortunately, this doesn’t work either, and the message can’t be saved.
Does anyone have a good method for debugging the function code inside the Apex Autorig Component? Any tips would be highly appreciated.
Additional Notes:
I’ve attached the .hip file for reference.
Even when connecting a void output, the issue persists.
I’m also wondering if there’s a way to tag nodes (such as functions or subnets) as traceable to automatically dump their inputs and outputs for easier debugging. This could really help streamline the debugging process.
Looking forward to your suggestions!
- edward
- 8122 posts
- gpss
- 7 posts
edward
No hip file attachment?
https://drive.google.com/file/d/1VaDJB6SGQASa4KIdhbenE3u7K9raADfv/view?usp=sharing [drive.google.com]
Debug method 1 didn't work. I found a solution for debug method 2, and it works, but the feature for automatically moving the index finger control doesn't seem to work
- edward
- 8122 posts
The problem is that a Log node by itself won't be executed if none of its outputs are evaluated. So you need to combine the debug methods where the Log node is also part of the evaluation path.
So I modified your method 1 to this and it seems to work:
#debug method 1 log_node = graph.addNode("mylog","Log") log_node.setParms({ "formatstring":"[Debug]{1}" }) log_node.setParms({ "severity":0 }) autoNode.target_out.connect(log_node.args0_in) autoNode.debug_out.connect(log_node.args_in) log_node.args0_out.connect(index_l.t_in)
- gpss
- 7 posts
edward
#debug method 1
log_node.setParms({ "formatstring":"{1}" })
edward, Thank you very much for your response. However, I tried it and it seems that the Log method still doesn't work. Although I can see the messages in the LogViewer, they don't seem to match the ones I want to print. Please take a look at the debug string returned by the compute function, as it is actually different.
def compute(v1:vector3, target:vector3, threshold:float=0.1, blend:float=1.0):
indexl=target
debug = f"threshold value: {threshold}, blend used: {blend}"
return target,debug
- edward
- 8122 posts
Sorry for the slow reply. You have two different Log nodes there that print different things:
- The Log_message in your screenshot is coming from the
- The
print(f"{target_pos}")that you have near the end of the Script code. This is executed when the autorigcomponent4 node runs.- The
f"threshold value: {threshold}, blend used: {blend}"message is only printed out when the `L_indexTarget_ik_t` input changes at animation time. But since there's no controller here that I can find, there's no way for you to change that value in the APEX Animate state, which is why it only prints out very rarely usually on the first run in the APEX Animate state, or when the viewport executes the rig.
