I want to evolve attributes over time, so that the values of an attribute depend on the values it had the frame before.
For example, the value of $ATT at frame $F depends on $ATT at frame $F-1.
I think I need the SOP solver in a dop network to achieve this. But how do I set it up?
Need SOP solver help
4656 7 2- Soothsayer
- 859 posts
- tjeeds
- 339 posts
- Soothsayer
- 859 posts
- dvfedele
- 33 posts
- tjeeds
- 339 posts
Well, I think that's a bit trickier. The reason the SOP solver is special is that it makes the geometry look at itself on the previous timestep. Without getting too technical, to get this to work with deforming geometry you'd need to get the amount each point is moving each frame and apply that on top of the sop solve. This is basically velocity/FPS if your timestep is 1 frame, so if you use a trail SOP to compute velocity on the geo before it goes into the sop solver you can apply that to the geo at each timestep.
Word?
Word?
Jesse Erickson
Fx Animator
WDAS
Fx Animator
WDAS
- tjeeds
- 339 posts
- circusmonkey
- 2624 posts
- Netvudu
- 304 posts
