In today's build of H11 (463) you can use the Vertex sop to cusp your vertex normals. Add a vertex node to the end of your chain and set Keep Normal to Cusp Normal, adjust the smoothing angle then you are all set. You can cusp polygons already with the Facet sop but in that case you actually separate the points where you want the cusping to occur which changes the point count and topology of the surface. The vertex sop keeps the surface intact and the number of points the same.
Robert
PS - In H11 you can also now see vertex normals in the viewport and since H10 Mantra could render them.
Vertex Normal Cusping
6679 9 4-
- rmagee
- スタッフ
- 1347 posts
- オフライン
- pbowmar
- 7046 posts
- オフライン
- circusmonkey
- 2624 posts
- オフライン
- old_school
- スタッフ
- 2540 posts
- オフライン
- Fabian
- 127 posts
- オフライン
- keyframe
- 1533 posts
- オフライン
- rmagee
- スタッフ
- 1347 posts
- オフライン
- keyframe
- 1533 posts
- オフライン
- pbowmar
- 7046 posts
- オフライン
- Alejandro Echeverry
- 691 posts
- オフライン
I have try to paint the cusp angle with an arbitrary attribute, but no luck!!
What can i do to have that type of control?
