why mplay pop up so slow?
5021
4
3
- gohalves
- 69 posts
when i start rendering, mplay takes about two minutes to pop up, and rendering so slow, what's going on?
- Erik_JE
- 300 posts
There are a lot of stuff done before the actual rendering is started.
For example preparing geometry and rendering shadow maps. This could be the reason for the delay of mplay opening.
Drive, monkey, drive!
- eitht
- 257 posts
Might also want the what machine you're working with. /wink
eitht.
- tamte
- 9637 posts
try disabling all network devices and see if that helps
If your scene has heavy image textures you could try converting them to .rat otherwise it needs to be done implicitly by Houdini.
