Hi, I removed a shelf set using this option:
Then after removing every shelf, I found that the blank space left won't allow me to add my shelves again.
Is there a way to restore the shelves maybe through a right click option?
I did find this hscript from the forums [sidefx.com]:
shelfdock -o 0
But it only opens/or closes the dock.
So after searching the help for other options for the shelfdock
I found this from the samples:
shelfdock -d Build add shelf_1 shelf_2
It works, and restores the shelves.
I was just wondering, if there is some kind of a shelf editor somewhere?
Restoring Removed Shelves
7253 5 1- galagast
- 252 posts
- circusmonkey
- 2624 posts
- galagast
- 252 posts
Hi Rob,
Thanks, I did try that option before.. sadly no luck.
I was experimenting with Desktops and created a layout with only the Scene view and Network view displayed Thus my custom desktop doesn't have any shelves.
So Reloading the current desktop only restores it to my custom desktop - without the shelves.
- circusmonkey
- 2624 posts
Hi, you should be able to reload your shelves from the menu. You hide them using that thin bar with the arrow to your screen left. I would re start Houdini. I cannot say I have ever run into your problem as I never see a need to fiddle with the shelves except that is to make my own shelf for my own tools.
Rob
Rob
Gone fishing
- galagast
- 252 posts
- circusmonkey
- 2624 posts
