Can anyone guide me in the right direction to do something like this?
https://vimeo.com/130774753 [vimeo.com]
https://vimeo.com/102580753 [vimeo.com]
Blending two objects with ripple.
8472 12 1-
- Joseph Langdon
- 23 posts
- オフライン
- verysame
- 59 posts
- オフライン
As a total newbie here have no idea, but in the description there are links, perhaps they can be helpful?
http://qlab.github.io/qLib/ [qlab.github.io]
second one is in Japanese though
http://nomoreretake.net/2015/06/16/houdinicarbonfreezing/ [nomoreretake.net]
Andrew
Houdini Apprentice
Houdini Apprentice
- animatrix_
- 5217 posts
- オフライン
It's easy to do with VDB tools. I created a simple example with the piggy model:
- Joseph Langdon
- 23 posts
- オフライン
- verysame
- 59 posts
- オフライン
Still, from newbie to newbie so, maybe I'm doing this totally wrong!!!
But since I'm moving my first steps it's kind of fun opening others' scene and try to figure things out.
I added an object merge, picking the mesh I want to use instead of the pig, and connecting to the xform. If I want to manipulate the new object, then I drop a transform node in between.
Did I get it right?
edit: ha! just noticed that I don't need a new xform node, I can simply use what pusat has added already
Did I get it right?
Andrew
Houdini Apprentice
Houdini Apprentice
- goldfarb
- スタッフ
- 3465 posts
- オンライン
- Joseph Langdon
- 23 posts
- オフライン
- Joseph Langdon
- 23 posts
- オフライン
- Joseph Langdon
- 23 posts
- オフライン
- animatrix_
- 5217 posts
- オフライン
Lower the volume resolution (voxel size) for faster playback. You can use Houdini Engine for C4D to bring it into C4D.
- verysame
- 59 posts
- オフライン
- Joseph Langdon
- 23 posts
- オフライン
Just wondering if anyone out there has any tips on getting the ripples to disperse from the object. I have attached a version that works how I want but I really want the object that is passing through to interact with the ripples.
Here is what I have so far.
http://dev.saatchi.no/smash/nuts/nuts_1.mp4 [dev.saatchi.no]
The end result I want to work like this…
The idea is to be able to swap out the .obj that passes through it…
Let me know if anyone can help. Smile
- Joseph Langdon
- 23 posts
- オフライン
