How to I use the same persp cam whether in /stage or inside a SOP Create LOP or inside an Instancer LOP and ideally even when in /Obj, as to do quick visual comparisons and not be jumping around as I navigate?
Cheers
Use same persp cam between stage and inside SOP Create LOP
560 3 1- ceee
- 1 posts
- jsmack
- 7850 posts
- Jonathan de Blok
- 257 posts
- colorbleed
- 9 posts
You could get your LOPs camera in /obj context with the LOP Import CAM node in /obj? It'll just end up acting as /obj level camera.
Vice versa you can use a Scene Import node in LOPs so that an /obj level camera becomes available in LOPs.
Would either of those work for you?
It's not meant to be manipulated in both - but you can at least enable it in your viewer in both then.
