Does solaris have the feature "select prototypes" in the viewer? just like the usdview does?
For example, if my prototype asset has several leaf primitives(mesh), switch selection kind to "Leaf Primitive" will only select the pointInstancer prim, switch to "Leaf Point Instances" will select the instance under mouse as a whole. So I wander if there a way to directly select the leaf primitives(mesh) from point instancer in the view?
Does solaris have the feature "select prototypes"?
381 2 0- Jobss_Soong
- 2 posts
- alexwheezy
- 209 posts
There is a special environment variable for this behaviour HOUDINI_PROTOPATHS_IN_INSTANCE_SELECTIONS
https://www.sidefx.com/docs/houdini/ref/env.html [www.sidefx.com]
- Jobss_Soong
- 2 posts
alexwheezyOh sorry for my delayed reply, this really helped me a lot, thank you very much
