How do I setup webhooks to monitor usage?
Important: Before you can configure webhooks, you will need to create an admin user for the license server (sesinetd).
Please refer to How do I add the admin user to the license server?
Checklist
Install a full copy of Houdini to the server.
Install a database backend. By default, SideFX webhooks creates a database using MySQL.
Next you can install and configure an application to read the tables from the database and graph the results. You can try something like Grafana.
Configuration
Setup your backend database user and password. By default, the SideFX webhooks will create the sidefx_webhooks database for MySQL.
Create a user and password with appropriate permissions to the sidefx_webhooks database and tables.
Edit the file $HFS/houdini/help/licensing/webhook/webhook_server.py where $HFS is the installation path of Houdini.
Copy the Signing Secret given by the License Administrator>Webhooks tab and copy it to the SIGNING_SECRET variable in the file $HFS/houdini/help/licensing/webhook/webhook_server.py. If you regenerate the signing secret in the License Administrator, you will need to copy it to the webhook_server.py file.
Edit the $HFS/houdini/help/licensing/webhook/webhook_server.py and ensure the python library matches your Houdini installation:
sys.path.append(os.path.expandvars("$HFS/houdini/python3.11libs/"))- Start the webhook using your database user and password:
python3.11 $HFS/houdini/help/licensing/webhook/webhook_server.py licenseadmin password
- Edit the URL in the License Administrator's Webhook tab:
http://yourserver.domain.com:8080/sidefx.webhook
- Once there is data populated in the database tables, you can setup another package to display the data, such as Grafana.
For more information, please refer to the documentation.
