How can I Start/stop the license server?
In some instances you may need to stop/restart the license server.
There are times when you may need to restart the license server such as when you are installing licenses manually. The license server is called sesinetd.
You must have "admin" rights (root, sudo) to be able to stop/start the license server.
Launcher
NOTE:
For locally running License Server(sesinetd) and Houdini Server(hserver) services only.
- Launch the License Administrator(hkey).
- Navigate to the services section in the left sidebar.
- Use the Start/Stop button to issue a command to the respective service.
You can start and stop the HoudiniLicenseServer in the Services area of Windows.
- Control Panel -> Administrative Tools -> Services
- The service HoudiniLicenseServer controls the license server program sesinetd.
Linux
- sudo systemctl restart sesinetd.service
