circle split……
   4437   4   0
I want such a circle, circle the number of points if the change in line with the changes will,
what is the way to do that?
Something like this? Be sure to toggle on Enable Sectors.
sop_ngon.otl (7.6 KB)
thanks graham, but I want to know how it works internally,I do not understand code,I hope it is the work of the network nodes。
a bit like 3d max extruder vertex
Changing the Arc Type parameter on the circle SOP from Closed to Sliced Arc should do the trick.
-dennis
Technical Reel 2015 [vimeo.com]
I want to achieve extrude the vertex and edge effects,but failed……
extrude vertex and edge.hip (86.5 KB)
