Bullet Masterclass
   5112   2   1
In this tutorial Jeff Wagner shows how to destroy a building.
One of the steps is to import and lock glue convex at geo level.
In the tutorial it was done with one or two clicks and I can't figure out how.
I unlock it and can't bring back.
building_rbd_step11.hipnc (490.5 KB)
The node he locked was fetch_objects_to_glue inside of the glue_piece0_to_piece99 object.
This is because otherwise, it re-imports each of the pieces each frame, killing performance and regenerating the glue network, often times.
You'll have to remember to un-lock, then re-lock that node if you change the pieces you're simming, otherwise the glue network won't update to see those new chunks.
I'm o.d.d.
speaking of the masterclass,
Jeff a some point walkthroughs a collapsing building hipfile he previously built ( rbd + debris + smoke ). Does anybody know where to retrieve that example?
Also, he briefly mentions a more complex constraint network used in a falling domino of bookcases and books, but can't find this example either.
thanks for your help
Luca
