How can I have the new particle system start emit particles on frame 20 and have it to end emit particles on frame 30?
Stig
Particle birthframe
4351 13 2-
- stigolsen
- 80 posts
- stigolsen
- 80 posts
- Sadjad Rabiee
- 1391 posts
You have “Turbulence” option in the “POP Force” node , Also you have some other parameters for controlling it's “Turbulence” noise such as “Swirl Size” or “Roughness” or Attenuation 8)
Just you should append “POP Force” node after “POP Source” in the AutoDopNetwork and set it's “Amplitude” to some bigger number :wink:
- stigolsen
- 80 posts
- stigolsen
- 80 posts
- Sadjad Rabiee
- 1391 posts
stigolsen
Thank you Joker.
I guess you mean I should append it after the “source” in the pop network, not the DOP network?
After the “source” I have a node called “wire pops into here”, and that is what you mean I should do right?
I dont have DOP network in this project yet.
Stig
That's not different for DopNetwork or POP Network , The Force node works correctly on both :wink:
- Sadjad Rabiee
- 1391 posts
stigolsen
It works very well.
The particles that I am tubulencing are emitted from a font. Do you know a good way the make the font go away (dissolve) on a particular frame?
The effect I want to achieve is the font dissolving to a particles that are flying away.
Stig
To create this Font effect you don't need to particles !
Please check Houdini_Mograph_Title_Design tutorial from cmiVFX if you can.
in this tutorial you will learn an interesting way to do that without particle system :wink:
- stigolsen
- 80 posts
- Sadjad Rabiee
- 1391 posts
- stigolsen
- 80 posts
Thank you very much!
I just think I made my self a little unclear.
Im only asking for a very basic thing; having a font (no particles, just pure text) disappear / dissolve to nothing.
For particles and stuff like that we have the creation frame, but for a simple font I cant figure how to make it dissolve to nothing.
In a compositing software its as easy as keyframing the opacity from 100% to 0%.
Stig
Stig
- Sadjad Rabiee
- 1391 posts
- stigolsen
- 80 posts
- Sadjad Rabiee
- 1391 posts
- stigolsen
- 80 posts
