Accessing a Varriable with Python SOP
   3519   3   1
Hi Everyone,
I'am using a phyton sop for testing simple stuffs. What here I want to solve a simple varible acces which varriable is not in definded in this code but earlier with a AttribCreate SOP. The problem is that the variable is not
accessable by its name.
How can I solve this ?
ThANKs!
– THE CODE –
node = hou.pwd()
geo = node.geometry()
# Add code to modify contents of geo.
# Use drop down menu to select examples.
points = geo.points()
for p in points:
p.setAttribValue( “A”, 1)
I think your meant is this code :
node = hou.pwd()
# Check if attr dosn't exist , then create it !
if not geo.findPointAttrib(“A”):
geo.addAttrib(hou.attribType.Point , “A” , 0 )
for p in points:
p.setAttribValue( ‘A’, p.number())
Rabiee.Sadjad@Gmail.Com
Thanks,
Sorry maybe you missed my point. I wanted to write to an attribute which
is created by a AttribCreate SOP and access that by only its name.
How can i do that ?
G
But that's work perfectly my friend , you should use setAttribValue expression !
I think your problem is for Attribute type , Integer or Float ?
If your attribute type in the AttribCreate SOP is Integer , So You should use Integer value in the Python Code and same rule for float.
Check attached project please :wink:
JKPythonSOP.zip (13.9 KB)
