Help with Shader
   2566   5   1
I'm currently working on a school project and the problem I've encountered is that my shader works fine on a low poly count alembic model but when I use it on a high poly count alembic model it doesn't work on it. Is there any answer as to why it's not working out ?
I want it to look like Error_02 but when I applied it it becomes like Error_01
What's type of your Alembic geometry ? Alembic type or Polygon ?
Try using Convert SOP after Alembic node , maybe your problem will solve :?
If not , can you upload any hip file ???
Rabiee.Sadjad@Gmail.Com
I tried using a Convert SOP but it doesn't work…
Help.zip (10.0 MB)
Chia Kang Lin
Ok let me to check it :wink:
Oh man , that's obvious !
the High Res Hand and Low Res Hand have different scale , Because you used Position for noise in the Displacement , So you should take different result in the different Scale and Position :idea:
And this is fixed hip file :wink:
ice_shaders_v9.zip (170.2 KB)
