Hi everyone. I'm former Softimage user and everything related to VOP's is more native for me, so I've tried to replicate attribute wrangle code in attribute VOP. The problem is - it is just not working as it should. I've attached an example file. Inside of a DOP network there is SOP solver connected to constraint relationship network. Can someone dive inside and check mine attribVOP please? There is also working attrib wrangle connected which is working perfectly fine so you would see what effect I'm trying to replicate.
Basically if attribute called angle is greater than some value - primitive must be removed. Attrib wrangle does the job, but not the attrib VOP.
