Smoke container delete resize_container node warning.
   3232   5   0
Hey guys! When I create smoke container and then delete resize_container I get warning message in smoke object ? After very long string the message says that it cant find SOP. I saw in a tutorial the guy deleting this node without any problem.
I'm using Houdini 13 apprentice .
hello.
i create sphere and apply volcano pyro fx preset to it.
after 240 frame i don't get any error.
but disable or delete resize container increase sim time because houdini use all voxel for calculate smoke while with resize container houdini use small (lower voxel) cube and grow by time and smoke so have faster sim.
NimaNolan
Thanks for your reply. In my mac it works perfectly. I guess it is some settings I have in my windows version.
I know what does resize node. I need entire fluid container because I'm using it to drive particle simulation.
cheers
If there are some expression references breaking up, you could just disable the resize node instead of deleting it.
you can go to resize container node and click on max bound tab then turn on enforce boundaries in all axes.
so in this case you don't need to delete or disable this node.
Thanks guys!
Updating to daily build solved the problem.
