hey guys, has anyone seen these weird values show up on floats after passing through an attribVOP that divides the sum of the values of a for loop by their count (i.e. average) ?
it seems very sporadic and causes sometimes this attribute to be invalidated in my next operations which is bad
any help to avoid or work around this issue would be appreciated!
pesky 1.#INF values showing up on floats?
4574 8 1-
- grayOlorin
- 1814 posts
- grayOlorin
- 1814 posts
- animatrix_
- 5193 posts
- grayOlorin
- 1814 posts
- grayOlorin
- 1814 posts
- animatrix_
- 5193 posts
Glad it worked
- edward
- 8126 posts
- grayOlorin
- 1814 posts
i'll double check my attributes but I think the non real number surged after summing the distance in between a point and all its neighbours inside a for loop. It also seems to oddly sometimes show up and sometimes not show up which is weird (but when it shows up, it “breaks” my attribute creation ): )
-G
- grayOlorin
- 1814 posts
ok upon further investigation, it seems like the infinite (1.#INF00) are being generated by the import into the for loop VOP (most likely since the index in my result screenshot is set to 0) OR potentially when calculating the distance in between this point and the neighbour points. it always seems to happen at the first iteration though
I suspect there may be a bug in the subinput VOP or the distance VOP that can sometime cause infinite numbers?
now that I can catch this, I am going to see if I can gracefully recover from it
thank you for the help!
-G
