Normalize scalar field
   5747   4   1
I have a volume and want to normalize the values min-max to 0-1
I did it with a python sop and numpy, but I thought I will better ask if there is a native houdini way to do that ?
www.woogieworks.at
hello my friend.
you can use VOP SOP node.
see this image:
Thanks for the Tip, but I have a 3D scalar field and want to find the minimum and the maximum Values of this scalar field and normalize the field that minimum becomes 0 and maximum becomes 1
www.woogieworks.at
Here's an example, the key is Volume Reduce SOP. There are a couple of extra nodes to get a scalar speed from vector velocity.
ee_field_normalize.hip (2.6 MB)
OK .. the volume reduce does the trick for min and max ..
but question :
whats the purpose of the
@name=speed
notation in the source group field
is it some kind of dynamic generated group ?
www.woogieworks.at
