Motion alone the path more ten one object
   2598   3   0
Hello I a question. I have to animate more ten one object alone a path.
For one object it is no problem. But I have to animate more objects.
I have now copied the path and object. But there must be a better way to do this..
Please give a suggestion
Ton
TEST.hip (155.1 KB)
If 10 objects are going down the same path and all you have to do is stagger them , just use a time shift sop and shift each object by X amount of frames
Gone fishing
Hi, Thank you very much for your advice, indeed it works very simple
Hi, I have done another ideafor this
Balletjes.hip (81.4 KB)
