Moving multiple curve points at once
   3155   3   1
Hi there,
I'm using the curve sop a bit lately to model a race track path and every now and then I've needed to tweak a large section of the track but there seems to be no way to transform multiple curve points at once.
Is this right? Say it aint so!
PPete
If in OBJ context maybe can not. But you can merge all curves in sop and tweak them.
I guess I could just make chunks of the track that I know will stay the same and then merge them and use the Join SOP to connect them?
http://www.sidefx.com/docs/houdini14.0/nodes/sop/join [sidefx.com]
When you say tweak them is that the kind of thing you were thinking of? Im just a little worried of it all getting a little over complicated…
Actually the edit node seems to be working fine, the only drawback is that it can delete points but I don't think you can add to them.
For that I'm just heading back down to the original curve op and adding there.
Thanks for the help.
Pete
