Hi All,
I am looking for a way to add procedural texture to the base color of a Mantra Surface. I can enable use map, but that only let's me browse to an image. I want to use some kind of noise.
Is that simple task built-in to Houdini or does that require modifying the Mantra Material itself at the node level?
How To Add Procedural Texture To Mantra Material
4979 2 0-
- Enivob
- 2658 posts
- anon_user_37409885
- 4189 posts
- Enivob
- 2658 posts
Thank you Marty, I guess I do have to modify the actual material at the node level. Middle Click is a nice menu to get going.
I did find an alterate way via mapping 2D textures from COPs into the Map field, once activated.
Circus Monkey has a nice tip on his website.
http://www.circusmonkey.com.au/circusmonkey/Cops.html [circusmonkey.com.au]
You can fetch the 2D pixel information directly from COPs by typing a special path to the COP network that holds the 2D texture. Prefix the path text with ‘op:’.
This is more C4D esk as far as material manipulation is concerned.
opimg/img1/OUT_TEXTURE
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
