Tron Lines
   3512   2   1
Hi all,
I want to make something like this, but in 3D
https://www.youtube.com/watch?v=8_QFzXDK588 [youtube.com]
these lines should gradually create cube like this
Thank you for your help
M
Here's a quick idea. ‘Find shortest paths’ will create lines between start and end points, over other geometry. Use this to create the random-ish paths (using a heavily distorted copy of the cube to help enhance the paths), then grow the curves with the carve sop.
Doesn't grow all the edges between all the points, but might be enough to get you started.
cube_tron_lines_v01.hipnc (86.2 KB)
mestela
Thank you a lot. I like it
M
