Can I transfer Houdini L-system animation into Maya?
3320 1 2-
- paris macadama
- 11 posts
- awong
- 818 posts
If you package up the L-system as an asset, you should be able to use it Maya through Houdini Engine. If your L-system outputs poly lines or curves, it'll be generated as curves in Maya. You can then render them in Maya.
You should be able to render them inside Houdini though. What do you mean it failed to render as an animation?
Andrew / アンドリュー
