Hi there,
When I parent an object that drives the position of other objects via blendpose - to a path-driven object, the blendposing stops working? In the attached example, the sphere_object1 is blendpose driving the tube and little box y position. But then it is childed under the box_object1 (large box, which is a path-driven object to the line in the center of it) and the blendpose doesn't work any longer. Is this by design?
BlendPose when child-ed not working
2235 4 0-
- caesar
- 143 posts
- 9384 posts
your file doesn't seem to contain anything
but from the description I guess you are driving your poses using local transforms of the sphere so if you move the sphere itself everything works, but if you parent it to something and move the parent, the local transform of the sphere will still stay the same, therefore your poses will stay the same as well
you can maybe extract world position of the sphere using Object CHOP and use that to drive your blendposes
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- caesar
- 143 posts
- 9384 posts
- caesar
- 143 posts
