Is it possible to specify custom environment variable in a way that it would be used to simplify path like variables such as $JOB, $HOME, etc do?
for example i want to define a $SOMEPRJ variable, that would point to some project structure i define an different hosts..
on linux i see that it maintains $SOMEPRJ variable as it is in file open menu, for example, but on windows it changes text to variable value when i pressing enter… so instead of $SOMEPRJ i got //server2/project/test_a on windows
also i want this custom variable to appear in Jump menu… is it possible?
6837 6 3-
- mlesin
- 176 posts
- old_school
- 2540 posts
Is it possible to specify custom environment variable in a way that it would be used to simplify path like variables such as $JOB, $HOME, etc do?This is up to you to define your environment. Houdini inherits all shell (linux) or system (windows) environment variables for you to use directly.
on linux i see that it maintains $SOMEPRJ variable as it is in file open menu, for example, but on windows it changes text to variable value when i pressing enter… so instead of $SOMEPRJ i got //server2/project/test_a on windowsWindows behaviour.
also i want this custom variable to appear in Jump menu… is it possible?In any houdini directory in the $HOUDINI_PATH ($HFS/houdini, $HOME/houdini<major_version>.<minor_version>, etc…), create a file called jump.pref and just put the path that you want to show up in the jump menu.
- mlesin
- 176 posts
- old_school
- 2540 posts
Nope.
If your environment variables ($JOB, $HIP, $HSITE, etc) use UNC paths, when you jump to them in the file browser the UNC paths will be preserved. If you type a UNC path into the file browser, that UNC path will be preserved. If you browse using drive letters (jump to drive X
then no, there is no way for us to preserve the mapping and the result is expanded.
Use unc paths.
then no, there is no way for us to preserve the mapping and the result is expanded.Use unc paths.
- mlesin
- 176 posts
- Simon
- 2199 posts
- 0chumpy
- 14 posts
