Hey,
I've been out of Houdini for a bit and wanted to get back into it. I download the latest production build and started to play around in it. But the first thing that I notices was that when I rotate the camera (alt+drag) it imminently crashes. I am able to do basic work in Houdini without it crashing. I am on windows 10 if that matters.
Has anyone seen this before/ know how to fix it?
Houdini crashes when rotating camera
3262 6 1-
- Jake Saladino2
- 3 posts
- mandrake0
- 655 posts
- Jake Saladino2
- 3 posts
After doing a bit more research it seems to happen when I try to “Show Handles” on any object on the object level. The Scene level seems to be fine. As long as I don't manipulate an object through the view port. Its still a big hindrance. I would appreciate any advice on how to fix this if anyone has seen it.
- mandrake0
- 655 posts
make a bug report to with the SESI Form:
https://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=25347 [sidefx.com]
you can check also the GPU driver maybe it's not the newest one or it's the newest and then use a older one :-)
it's hard to analyse…..
- Jake Saladino2
- 3 posts
- tonyangl
- john21wall
