Hi
Just a question re Houdini and open cl on a gtx 1080 when using the flip solver.
So from what I understand if I click the use the open cl check box in the solver the flip solver will use the gpu if it's recognised by Houdini.
If I look in the about Houdini window it's listed there but I don't see any activity pushed toward the gpu and no significant increase in performance.
Is this because I'm using pop forces in dops?
I think Jeff Wagner mentioned something about this in todays flip webinar but it was 4.00am in the morning here so I may have misheard that?
thanks
Nigel.
Houdini, Open cl, gtx 1080 and the flip solver?
4496 5 2-
- nigelgardiner
- 48 posts
- nigelgardiner
- 48 posts
- anon_user_37409885
- 4189 posts
It will use it, the most obvious place it GPU acceleration shows is when you use grains. You should have a nice speed up there. Flip isn't fully OpenCL'd yet but…digging into the HDA it is interesting is that some nodes like Calc_curlmag has an OpenCL checkbox but it isn't toggled on by the ‘flipsolver’ openCL checkbox…
- nigelgardiner
- 48 posts
- animatrix_
- 5118 posts
Artye
nigelgardiner
Thanks Artye.
So it may be worth digging into the flip solver, hunting for open cl check boxes, setting to on and seeing what happens?
cheers
Nigel.
Don't do that. This is by design. There is no point switching to OCL for only a single light weight operation.
According to SESI the Use OpenCL predominantly controls if the pressure projection runs on the GPU or not.
Edited by animatrix_ - Sept. 9, 2016 20:46:14
- nigelgardiner
- 48 posts
