Hi all,
I find myself in a situation where I need to use a 64bit integer in order to create an unique id (and there is no other way around it). However, wrangle nodes and VOPs seem to be limited to 32 bit, so the question is - how do you perform calculations on 64 bit integer attributes?
I've attached a simple scene that demonstrates the problem, in which you can see that the attribute ‘a’ becomes screwed up because it exceeds a 32 bit int, even though teh variable is 64 bit.
64bit integer attribute
2983 3 1-
- Anti-Distinctlyminty
- 271 posts
- ttvdsfx
- 173 posts
- pezetko
- 392 posts
- 271 posts
