Hello! I have a scattered model falling into lot of pieces, and i add a noise of red color so the pieces with Black color turn red, and i would like to scale the pieces depending on the amount of red.
So if the res is 1, the size of the pieces is 1.
How can i do that? Im sure ill need to use the foreach but i cantón get these effect.
Tnanks forma all!
How to scale pieces of a dynamic object depending con color??
2321 1 0-
- david0311.fx
- Enivob
- 2658 posts
You don't really need a for loop, just an AttributeWrangle (which is essentially a multi-threaded loop processor) running over the primitives.
This will set the scale equal to the red color. You can also multiply the scale as needed.
v@scale = set(v@Cd.r,v@Cd.r,v@Cd.r) * 1;
Edited by Enivob - Dec. 12, 2016 12:42:30
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
